How to fill
Old Jul 14, 2005 | 10:08 PM
Ford150/428/dud's Avatar
Ford150/428/dud
How to fill
Hey im patching my floor boards and im wondering if i should grind all the paint and rust off and put the filler right on the bare metal. Or should i paint it with por 15 first them fill over it. Also can i put por 15 over filler? My filler is evercoat with short strand renforcement, and its water proof.
Old Jul 15, 2005 | 09:24 AM
sevenL4's Avatar
sevenL4
The folks at POR recommend you clean the area of paint and any loose, scaly rust. Wipe it with lacquer thinner or acetone. Brush on POR, lay fiberglass cloth in the POR, brush on more POR. It worked for me on a '56 with some pinhole rust-thru damage.
discochris's Avatar
discochris
I just finished my floors. I just seam sealed the welds and painted over with Zero Rust - I'm not going to bother with filler, since I'll be carpeting over the floors, and thus nobody will see it.
If you're not welding the patches in, I'd go with fiberglass rather than filler.
Old Jul 15, 2005 | 12:28 PM
Ford150/428/dud
OK ill go wit the fiberglass sheet and the por15. So should i do the same thing on the chrome trim holes on the body.
