Code help- again Help!!!!!
Old Jul 14, 2005 | 07:39 PM
alcooner's Avatar
alcooner
well after a week of no check engine light and Ford dealership telling me they could not pull a code, the light was back on again today. Me and wife ran KOER test and got codes, 129, 167, and 225. I need help. When light is on bad runing and no power and fuel loss. I have changed O2, IAT sensor, all hoses going to canister and canister purge valve.
The Ford Dealership says light comes on because of 233,000 miles I think that is horse crap.
thanks
Old Jul 14, 2005 | 07:52 PM
924x2150's Avatar
924x2150
There were no codes at KOEO or Continuous code test? If the engine light came on why isn't there a stored code from the last 80 cycles.?
The three codes may be related to not stepping on the gas hard or long enuf. I get 225 50 percent of the time during KOER, I think it is operator (me) error.
Old Jul 14, 2005 | 08:01 PM
alcooner's Avatar
alcooner
Just ran another check and got a 225, 129 so 921x2150 I think I will try replacing the MAP sensor, that is about the only one I have not replaced.
thanks guys
anymore input is appreciated
Old Jul 14, 2005 | 08:14 PM
93nighthawk's Avatar
93nighthawk
129 - No MAP or Mass Air Flow sensor change during "goose" test
167 - 167 No Throttle Position sensor change in "goose" test (must get at least 25% rotation)
225 - Knock sensor not tested (ignore if not pinging)
I would first clean your MAF with Electrical contact cleaner, if that does not work, then replace. (129)
(167) is an error on your part on the test by not goosing it enough. Easy to do.
225- same here, half the time it shows up.
I would also run a KOEO and engine balance test, just to make sure.
Old Jul 14, 2005 | 08:45 PM
MemOrex's Avatar
MemOrex
Alcooner, are you hitting(goose) the gas pedal during the KOER test?. During the KOER test you'll see a single blink almost at the end of the test....this is the indication to goose the gas. Just a quick rev at least 1/2 way down.
Old Jul 15, 2005 | 08:45 PM
alcooner's Avatar
alcooner
I replaced the MAP sensor today, unhooked battery to reset codes. Well Engine light on again. Ran the KOER again and it still showed 129-MAP code. Got to fooling with vaccum lines and took one off going to throttle body and light went off and has not come back on. But still getting MAP code.
These emmision problems are a pain in the butt. Maybe my dang truck is wore out. Gonna change some vaccum lines tomorrow.
Any more suggestions are welcomed. I am at the end of my rope.
thanks
