Oil Problem
Old Dec 18, 2002 | 07:52 PM
dweg's Avatar
dweg
Oil Problem
Hey All, I have an oil problem maybe someone can shed some light on. I first started noticeing oil on the left front(standing in front of the truck) of the motor, couldn't see where it was coming from. Finally found out it's coming back out the oil fill tube. Question is why? Any input would be helpful, Thanks
The truck is a 79 F-150 351M
Old Dec 18, 2002 | 08:34 PM
Mil1ion's Avatar
Mil1ion
Oil Problem
Blow-by from the piston rings wearing out, and/or the oil filler cap could be plugged.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 19, 2002 | 09:30 AM
beartracks's Avatar
beartracks
Oil Problem
PVC valve or breather plugged?
Old Dec 19, 2002 | 10:27 AM
dfisher1's Avatar
dfisher1
Oil Problem
dweg,
Check the valve that goes from the oil fill cap, or from the other side of the motor's valve cover, to the back of the carb. This PCV (proper crankcase ventilator) insures a negative pressure in your crankcase. When it clogs, pressure builds up and it leaks out every hole. There is a leak at the base of your oil fill stick tube and that's close enough to the oil for it to blow oil out there. Change your PCV and hope that that's it. It's a cheap fix.
KingFisher
Old Dec 19, 2002 | 03:50 PM
KJKozak2's Avatar
KJKozak2
Oil Problem
I had the exact same problem with my 460 when I first got it. I checked and cleaned all the hoses, PVC valve, and breather. Whatever I did, it solved the problem. I also put a little RTV in the cap of the dipstick to give it a little extra seal. I had a spare water pump thingy with a tube on it so I didn't have to risk getting RTV in the engine.
Kevin K.
Old Dec 19, 2002 | 06:15 PM
0u812's Avatar
0u812
Post Oil Problem
