spout
Old Jul 14, 2005 | 12:53 PM
merv1's Avatar
merv1
spout
hello everyone i'm trying to check the timing on my f250 /460 motor i think i need to disconect the spout before i start, the trouble is i can't find the spout what does it look like? what is it hooked to ? where do i look for it on a calif. f250 thanks in advance merv
Old Jul 22, 2005 | 03:13 AM
karljay's Avatar
karljay
The spout is a square plastic plug very near the dist. It just holds two wires closed, then you remove the plug and the wires are open. Look at all the wires from the dist.
Old Jul 22, 2005 | 09:07 AM
merv1's Avatar
merv1
what i see on my 95 is what you discribed but it is way over buy the fender/firewall it has two red wires going in and a gray looking plug on the other end thanks for the reply
Old Jul 22, 2005 | 09:15 AM
wtroger's Avatar
wtroger
That is it they moved the ignition module. It is mounted on the fender drivers side not on the dizzy.
