Sponsored by: Real Truck
Confusing tire sizes
Old Jul 14, 2005 | 11:22 AM
Steve_250's Avatar
Steve_250
Question Confusing tire sizes
I'm a little confused at how tires are sized.
I see stuff like 285/75 R16 up to 315/75 R16 and such, then I see 31, 33, 35, etc.
HUH???
Straight out, I have original 265/75 R16 and I want to go up.
I do NOT want a lift on my '03 PSD but want max tire size.
What will work?
I am interested in BFG mud terrains.
Old Jul 14, 2005 | 11:43 AM
BlkF250psd's Avatar
BlkF250psd
Steve 250
Max tire without lift 295-75-r16. Check out this tire calculator.
http://www.miata.net/garage/tirecalc.html 31,32,33 equals overall height of tire.
Old Jul 14, 2005 | 11:45 AM
wlihntr's Avatar
wlihntr
there are metric sizes and standard sizs, 285/75-16 (metric) means the tread width is 285 mm wide and the side wall height is 75% the tread width of the tire, 16 is the wheel diameter. a 33/12.5-15 is a standard size, 33 inches tall 12.5 inches wide and 15 inches wheel diameter.
Old Jul 14, 2005 | 11:59 AM
Steve_250's Avatar
Steve_250
Ok, with ya so far, but how can I tell what the rim width is, 7, 7.5, 8?
Is it half of the R16?
I want to use the same rims and I know some tires specify wider rims.
I looked at the calculator but it doesn't tell me what the stock rims will accept.
Comparison with 295's on the above link:
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
265/75-16 7.8in 15.8in 31.6in 99.4in 637 0.0% (stock)
295/75-16 8.7in 16.7in 33.4in 105.0in 603 5.6%
Will the 295's fit on my rim?
Any wider tires?
Old Jul 14, 2005 | 12:15 PM
NoMo's Avatar
NoMo
Rim width is not given by tire size. Your factory rims are 7" wide. Check the tire manufacturer's website to see what rim widths they recommend for their tires.
Old Jul 14, 2005 | 12:30 PM
dmp437's Avatar
dmp437
The B F Goodrich site recommends a 7.5" rim for both the 285 & 295's.
However, lots of guys run wider tires than what the manufacturer mandates. I ran Goodyear 305's for 40,000 miles on 7" rims. They won't wear correctly but other than that I never had a problem.
