Sponsored by: Real Truck
Power window problem
Old Jul 14, 2005 | 09:52 AM
gw90r8's Avatar
gw90r8
2001 F-250 XLT std cab
Drivers side window will not go down, up function works normally. Passenger side works fine. I do not have a scan tool.
Switch tests good with a meter.
Motor works in both directions when plugged into harness on the passenger side.
Relays in the fuse box have been switched.
When power is applied to the to the drivers side window circuit, with the appropriate relay removed to isolate the GEM module, all works well.
This leads me to suspect the GEM module has a problem, is this a dealer only area?
Has anyone had to have their GEM replaced, reprogrammed etc. Any ideas of $$$?
Thanks in advance
Gary
Old Jul 19, 2005 | 04:14 PM
Bulldog05's Avatar
Bulldog05
will the window go down if you push down while the motor is going? My 99' sc windows would go down great if the glass was wet and slow when dry, but i could push them down while the motor was trying. It seems like the track guides may need some replacement/realignment. I've heard the glass can move out of the bottom slot as well. Ask a body shop they'll know!
Old Jul 19, 2005 | 04:40 PM
FortyFords's Avatar
FortyFords
do you have a schematic your using?
Old Jul 19, 2005 | 05:07 PM
99f350sd's Avatar
99f350sd
You're right Rich its either a wire or connection or switch. Usually switch..
Old Jul 19, 2005 | 05:17 PM
FortyFords's Avatar
FortyFords
99 I edit out my test because I want to make sure he has a schematic first!
then I'll put it back
Rich
Old Jul 20, 2005 | 08:08 AM
gw90r8's Avatar
gw90r8
I have a schematic on CD. The CD is from Ford titled Ford Technical Service Information Electronic Publications.
Gary
Old Jul 20, 2005 | 12:23 PM
99f350sd's Avatar
99f350sd
Do you have the one touch down system? Does the relay click?
The gem module is a dealer change issue.
Old Jul 21, 2005 | 06:42 AM
gw90r8's Avatar
gw90r8
Yes I have the one touch down system and the relay clicks. I am waiting for Forty Fords test procedure before I go any further.
