fuel guage
Old Jul 14, 2005 | 07:21 AM
Faltura's Avatar
Faltura
Thumbs down fuel guage
I have a 72 F-350. The fuel guage never gets above 5/8, even with the tank spilling over. I have tried different fuel sending units that I had laying around and they give me the same reading on the guage. I noticed that my temp and oil guage run on the low side. Could this be a guage voltage regulator problem?
If so is there an easy way to check it? Where is it located? I would appreciate any suggestions on this one.
thanks
Old Jul 14, 2005 | 09:36 AM
billemc's Avatar
billemc
If it is like my F100, the regulator is located behind the instrument panel at the rear of the gauges. I think it regulates down to 8 volts, but someone might correct me on this. Hope this helps. Billemc
Old Jul 14, 2005 | 09:56 AM
fellro86's Avatar
fellro86
It sure sounds like a regulator problem, the voltage isn't enough to pull the needle over. The regulator is the relatively big box like thing with the 9 volt battery like plug in, if I recall correctly.
Old Jul 14, 2005 | 10:25 AM
Tech 1's Avatar
Tech 1
Smile Instrument panel voltage regulat
This is located on the back of the gauge cluster and snaps on the printed circuit board like a 9 volt battery as fellro86 described. I think there is an article in the articles/specs section on this site about setting it up to work better, but I haven't done a search for it.
Old Jul 15, 2005 | 01:22 PM
Faltura's Avatar
Faltura
Thanks guys. I need to take the instr. panel out for bulb replacement. Guess that will be good time to check it out.
Old Jul 18, 2005 | 02:35 AM
71_4x4_390's Avatar
71_4x4_390
Faltura
Have you checked to make sure the float in the tank isn't full of fuel? If it is it will never read correctly on the gauge.
Just a thought
