pcv valve
Old Jul 12, 2005 | 11:33 PM
rogerp1000's Avatar
rogerp1000
pcv valve
I'm sorry for the stupid question about the egr valve,i knew where that was. It's the pcv valve that i can't seem to find. I have a 1998 explorer 5.0 2wd.
Could you help me locate it? It's nowhere on the valve covers.
Old Jul 13, 2005 | 02:14 PM
gibsonj's Avatar
gibsonj
On the 97 Explorer, it's pretty well hidden at the back of the engine underneath the intake cover. It has a "T" connector in the vacuum hose attached to the PCV valve.
Basically have to feel for it on my 97. It's not obvious. Might be able to see it with a spot mirror.
Old Jul 13, 2005 | 09:18 PM
Jharger's Avatar
Jharger
PCV valves are always located on top of a valve cover. I've never seen one in the middle so either the front or rear as the other poster noted. There is a rubber hose on the top going into the air intake somewhere.
Old Jul 13, 2005 | 11:39 PM
rogerp1000's Avatar
rogerp1000
Thanks,it is located in the back near the bottom,but,i don't need to change it,so i won't have to go through the trouble for now.
