Determining coil spring sag
Old Jul 14, 2005 | 08:06 PM
Mil1ion's Avatar
Mil1ion
In 1990 my coils springs were so sagged,they couldn't/wouldn't align my truck.
OEM app = 400 w/o air
I replaced them with the 460 w/air application.
Huge difference
Old Jul 14, 2005 | 11:41 PM
rfxj3's Avatar
rfxj3
OK Gene, What would your spring guy attribute this front end rake to then - all suspension components (except shocks and radius arm buishings) are original equipment and the tires are 235*70R15 on 15x7 rims. I am not trying to be confrontational but if my assumption is wrong, I am about to spend a couple of hundred bucks on the wrong solution. It is a 302 w/ 3 on the tree AT swapped engine in place of the original 300 straight 6 w/ 3 speed manual on the tree. Don't think there is much of a weight difference there. Am experiencing oversteer problems as well.
https://www.ford-trucks.com/user_gal...=50615&width=0
Old Jul 15, 2005 | 12:21 AM
GeneStoner's Avatar
GeneStoner
Well. I don't know what he would say, but that looks about the same rake as mine, 'cept I'm running 285-60-18's (which works out to a 31.46" tall tire and 11.22" wide).
All I know is I have to do something before I tear up my fenders/tires...
Old Jul 15, 2005 | 12:24 AM
rfxj3's Avatar
rfxj3
Well, I guess I am going to go with the new spring option - will report on the results when I get them installed. Heck, if nothing else - they can't hurt right?
Old Jul 15, 2005 | 09:54 AM
Ecuri's Avatar
Ecuri
I liked the tack Eric took, if you measure from the bottom of the frame rail straight down to the top of the I-Beam what do you get? (In other words, how far can the I-beam travel before it hits the frame rail?) All the trucks should have a "sweet spot" regardless of engine or tire combo that provides for the optimimum bump and droop travel, and allowance for camber adjust without a HUGE bend to the beam.
With cast beams I have 3.5" +/-1/8 (and have a good alignment, handling, etc.)
Maybe with a few more people checking on know good trucks, we can establish (verify) what is the normal range.
Old Jul 15, 2005 | 11:24 AM
Lane Dexter's Avatar
Lane Dexter
I think these springs DO sag, though I certainly don't have a large enough statistical sample to comment on how often.
The other day, I had my '77 F250 (2WD Custom w/ 351M & C6) on Diablo Dam, and I parked as close as I could to the upstream parapet wall, so the right side tires just touched the wall. Comparing visually to a rail set into the roadway, I first thought the front track must be an inch or so narrower than rear (my stupid '96 K2500 Suburban is a good 2" wider in front), then I noticed the left front tire seemed to have more positive camber. My eyeball said it was definitely tucked in, compared to the rear tire.
Now I'm confused. But a short time after I got the truck, I saw the front bump stops were about beaten out of existence, and one side seemed a bit lower. I ordered new red urethane bump stops from Springworks. I'm sure my springs have sagged somewhat, and maybe someday I'll install new ones. But for now, we just avoid the jumps.
This is the Real World. Coil springs sag. Leaf springs sag. Torsion bars sag. Hell, I sag.
Old Jul 15, 2005 | 10:22 PM
GeneStoner's Avatar
GeneStoner
Well I'm sitting at 3.25" from the top of my I-beams to the bottom of the frame on both sides. Looks like I sagged at least a bit...
Old Jul 16, 2005 | 01:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
At least it is even. A spring spacer may even work since the springs seem to be basically OK.
On my F250 the 265/75R16 tires rub a little in extreme turns but not enough to bother anything.
Old Jul 16, 2005 | 02:29 AM
Lane Dexter
Now THAT'S useful data. I presently have 235/85R-16E's on my 2WD 1977 F250 Custom. I'm planning to go to 265/75R-16E's to increase my load rating (and match what I'm running on our Suburban). My front springs are sagged just a bit, I believe. I intend to add Hellwig Load Pro LP25 helpers to the rear, so I'll be stable with a cord of wood. Sounds like I'd better watch my front ride height closely with the 265's, but it should work OK.
Thanks.
Old Jul 16, 2005 | 07:52 PM
GeneStoner's Avatar
GeneStoner
Where does one get a "spring spacer?"
Old Jul 17, 2005 | 01:37 AM
Lane Dexter
Google thinks like I do on this one. First hit on a search was J.C. Whitney. Good old jcwhitney.com will have lots of suspension bits.
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
Here's an article on a different kind of coil spring spacer -- for a lift kit -- on a Toyota 4x4. I suppose this happens on Broncos, too.
http://www.4x4wire.com/toyota/reviews/coilspacers/
Here's a performance outfit with spacers and some interesting adjusters.
http://www.budzter.com/ Maybe not what you want, but it sure is interesting.
Here's an off-road outfit offering Jeep spacers.
http://www.4wheelerssupply.com/catal.../products_id/1
Here's an outfit selling "lift your truck" urethane spacers.
http://www.jackit.com/springs/coil_spacers.htm
This outfit has "Ford leveling kits," though I seem to have hit the ones for later models.
http://www.suspensionconnection.com/...F09101F1L.html
Springworks sold me some good bumps stops a while back. I'd expect them to have coil spacers.
http://www.springworks.com/
Trust me, if you search for coil spring spacers on Google, you'll find more than you know what to do with.
Old Jul 17, 2005 | 02:16 AM
Torque1st's Avatar
Torque1st
Posting Legend
The type that might work are just a rubber pad that fits under the coil spring on one end. The last ones I saw were in a parts store. Sorry I don't remember which one.
They were similar to the JC Whitney 84UE0661Y (# from a 2003 catalog) but not as tall. They were about 3/4" thick. You don't need much lift and the rubber will help the ride quality.
Old Jul 17, 2005 | 11:15 AM
  #28
Mil1ion's Avatar
Mil1ion
Moog makes spring pads available.
Old Jul 18, 2005 | 01:25 PM
  #29
GeneStoner's Avatar
GeneStoner
Do you think spring spacers will affect the camber situation?
Old Jul 18, 2005 | 01:37 PM
  #30
rfxj3's Avatar
rfxj3
Will let you know - just ordered from Whitney yesterday - figured was a cheap way to test if that was my problem. If it does solve my oversteer and camber issues, I will probably go ahead and just buy new replacement springs but figured for $20, it might prove it one way or the other.
http://www.jcwhitney.com/autoparts/I...D:100000233647
