what transmission do i have?
Old Jul 12, 2005 | 08:44 PM
5.8L95f150's Avatar
5.8L95f150
could some one tell me how to read the VIN number or just tell me what kind of transmission i have. i have a 95 f150 5.8 4x4.
Old Jul 12, 2005 | 09:00 PM
quicklook2's Avatar
quicklook2
so are you going to give us a hint? auto or stick?
Old Jul 12, 2005 | 09:11 PM
Pantera-nm's Avatar
Pantera-nm
There is a sticker in the drivers door jamb. Check under the TRANS section. You will find a code there. Depending on what code it is, you will be able to identify the type on transmission in your truck. In my case, it was U , and that means I have a 4R70W. I believe E means E4OD. There are some other codes, but I dont know them.
Old Jul 12, 2005 | 09:20 PM
302s&460srocks's Avatar
302s&460srocks
I'm pretty sure it's an E4OD
Old Jul 13, 2005 | 04:29 PM
EPNCSU2006's Avatar
EPNCSU2006
I'm also pretty sure it's an E4OD; they didn't put stick shifts behind the 5.8 in F150's (except for '88).
Old Jul 13, 2005 | 09:32 PM
Rotor's Avatar
Rotor
E40D sounds right to me too but if it's a 3-sp it's probably a C6
Old Jul 14, 2005 | 06:16 AM
jroehl's Avatar
jroehl
FTE has all you need to know:
https://www.ford-trucks.com/article/...ers_Guide.html
Jason
