Sponsored by: Auxito
transmission identity
Old Jul 12, 2005 | 01:09 PM
lancekilgore's Avatar
lancekilgore
Hello I am trying to I dentify the Transmission I have on this used 2000 Ford F150 XLT. It has a 4.6 engine. the book says there are two different transmisions. I have looked all around the transmission to no avail. Any help out there.
Thanks in advance
Lance
Old Jul 12, 2005 | 02:44 PM
l-m tech's Avatar
l-m tech
if it is a automatic it should be a 4r70w.i havnt seen a 4.6 with a e4od.
Old Jul 12, 2005 | 04:18 PM
triton_2002's Avatar
triton_2002
The transmission code is on the door sticker. It should be code "U" = 4r70w as stated above
Old Jul 12, 2005 | 06:29 PM
lancekilgore
Nope nothing on the Door sticker like that, The only ting I can fine is on the dip stick it says to use Mercon V. which would indicate a 4r70w tranny. I guess I will be very concerned now because it that is what is in the truck then I used the wrong fluid 1000 miles ago. and it is throughly mixed by now. So if that is the case what damage is being done to the tranny now.
Lance
Old Jul 12, 2005 | 06:37 PM
ford390gashog's Avatar
ford390gashog
how did you ad the wrong fluid if the dipstick says to use mercon v? the tranny code is on the tag on the door it will not say a 4r70w it it will give a code what is the code?
Old Jul 12, 2005 | 06:49 PM
lancekilgore
I did not pay attention to the dip stick, Dummy I know. ok I'm back here are a few codes on the door sticker, tr=U, r=5, spr=6N, Axle=H9, Does that help?
Lance
Old Jul 12, 2005 | 06:52 PM
lancekilgore
guess I had better learn to read better u are right I have a r470w. so what damage can occure. Or better what have I done?
Lance
Old Jul 12, 2005 | 06:56 PM
triton_2002
Like I said TR (transmission) code "U" is the 4r70w.
I would take that truck to a tranny shop and have the tranny flushed/ replace filter fill it up with the correct fluid and hope for the best.
Old Jul 12, 2005 | 06:59 PM
ford390gashog
you will ruin the torque converter or clutches,but how much of the wrong fluid did you use? if its no more than a quart you will be fine, but you still need to have it flushed and filled with mercon v . mercon v has special friction modifiers to help with the torque converter shudder.
Old Jul 12, 2005 | 07:01 PM
lancekilgore
i'll take care of it tommorow. Thanks hope fully I did not do any damage.
Lance
