Power Steering
Old Jul 12, 2005 | 12:54 PM
bshackelford711's Avatar
bshackelford711
Power Steering
Is it a kit out their some where to add P/S to a 1956 F-100?
where can i find it and for about how much?
Thanks
-Brandon-
Old Jul 12, 2005 | 02:53 PM
AXracer's Avatar
AXracer
Mid Fifty and others sell several different PS systems to add to your truck. The Toyota truck PS box is the easiest, least expensive, most popular, highly recommended. Other options are ram assist, GM box. Prices depend on if your donor parts are new/rebuilt/used, and how difficult adapting a PS pump to your engine is. Expect to pay between 300.-1000.00 if you DIY.
Old Jul 12, 2005 | 03:10 PM
Daplumma's Avatar
Daplumma
I installed a bendex p/s setup.Bolted right on with no modifications.Make sure you install a cooler on it.My truck is not a daily driver and the bendex setup is prone to failures.I think the setup was used on the 67-69 trucks.Make sure you get the setup from a fe truck if you have a fe truck.Get all of the brackets and pulleys also.You can also adapt a frod setup from trucks all of the way up to 1978 but the column may have to be modified.Do a search,this topic had been gone over many times here.Good luck.
Old Jul 12, 2005 | 03:12 PM
Daplumma's Avatar
Daplumma
Sorry wrong forum.Thought I was in the 61-66 forum and you had a 1965.Good luck to you.
Joe
fitter565
West Virginia Chapter
28
Oct 7, 2005 07:50 PM
Ratsmoker
Dec 4, 2002 06:07 PM
rbastedo
Aerostar
Sep 9, 2002 07:51 PM
horsepuller
Jun 13, 2002 09:55 PM
Amule
Feb 3, 2002 11:10 PM
