Sponsored by: Auxito
Front shock mount split
Old Jul 11, 2005 | 10:13 PM
geolguy's Avatar
geolguy
After a bumpy chuckhole road, I happened to walk by the front right tire and noticed that the top mount for the shock had split down the middle and the top of the shock is out of the mount and flopping around. It looks like the top shock bracket is welded to the frame. Is this easy to fix? Looks like I will have to plasma cut off the old mount and weld in a new one. Are these top shock brackets available at a parts dealer or is this the kind of thing that requires a visit to the wrecking yard to cut one off? Any help is appreciated.
Old Jul 12, 2005 | 06:17 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
