Problem - turn signal - need help
Old Jul 11, 2005 | 09:57 PM
Cyberbug's Avatar
Cyberbug
Question Problem - turn signal - need help
This is the second time it has happened. The turn signals both left and right freeze when used, the lights and the LED insight just freeze instead of blinking. The bulbs are ok.
It happened also couple of months ago, but overnight got fixed on its own.
Today the signals got frozen again, same way, no blinking. every thing else works fine in the truck.
I had to park the truck for four hours, and after that they were fine, but only for 10 min and same condition occured again.
I wouldn't be suprised if they are fine in the morning.
Any idea's from anyone please, as to what may be causing it and how I can fix it? Thanks in advance
The truck is a F-150, 1994
Old Jul 11, 2005 | 10:03 PM
quicklook2's Avatar
quicklook2
maybe the relay is shorting out when it is hot, when it cools it works again.
Old Jul 12, 2005 | 08:46 AM
Cyberbug's Avatar
Cyberbug
Thanks, it was working fine this morning again.
That could be it, where is this relay located? I would like to replace it myself.
My inspection is coming up.
regards,
Old Jul 12, 2005 | 09:17 AM
quicklook2's Avatar
quicklook2
round relay in fuse box under dash.
Old Jul 12, 2005 | 11:28 AM
Beast12's Avatar
Beast12
Yeah it is your flasher (relay). Like Quicklook said it is in the fuse box and it is the round one.
-Matt
Old Jul 12, 2005 | 09:08 PM
Cyberbug's Avatar
Cyberbug
Thanks guys, Found the flasher relay there are two round relays one in the back of the flasher relay don't know what that is for.
Now I have been searching for the flasher relay online but can't find the part.
any ideas where I can get it.
Old Jul 12, 2005 | 09:13 PM
quicklook2's Avatar
quicklook2
the one on the back is for 4 way flasher. any auto parts store has this for cheap.
Old Jul 18, 2005 | 09:21 PM
Cyberbug's Avatar
Cyberbug
Thanks, couldn't find it online so I will visit the stores, Its been acting up a lot lately its been raining a lot. I tap it with my finger nails and it starts working again.
