1978 - 1996 Big Bronco
weird hissing sound!!!
Old Jul 11, 2005 | 05:35 PM
XolieX's Avatar
XolieX
lately after i turn off my bronco and i walk infront of it, i hear a noticable hissing sound coming from right about the trans cooler or radiator. it slowly goes away in about a minute or two, but it does go out everytime in about the same amount of time.
think it could just be something with my a/c? i've been running it everyday with this 100 degree weather daily.
or do you think its more serious like a small leak in the trans cooler or radiator? i don't detect any leaks though.
what do you guys think it is?
Old Jul 11, 2005 | 05:52 PM
ctch88's Avatar
ctch88
Check the radiator cap. When the coolent gets hot, it's volume increases. I'm sure you knew this, but anyway, if the coolent runs out of room in the radiator, there is a bypass line that brings it back to the resivoir. The added pressure on the radiator cap could be making the noise. Just an idea.
Old Jul 12, 2005 | 12:03 AM
justshootme84's Avatar
justshootme84
Yeah, changing the radiator cap every year is cheap insurance. IF the temp is getting that hot to overheat the radiator/ trans cooler, look at changing the thermostat, or at least cleaning the radiator and cooler. I get about 5 lbs. of debris behind mine each year that needs to be vacuumed out.
Old Jul 12, 2005 | 05:34 AM
Big Daddy J's Avatar
Big Daddy J
My 87 does the same thing after stopping and running the a/c. I just thought it was from the a/c system somehow, kinda cooling down or releasing pressure...it's been doing it since I bought it back in 99 and I've had no problems.
Old Jul 12, 2005 | 09:21 AM
BillyBob69's Avatar
BillyBob69
I had the same thing on my 85 FSB and now also with my 02' F150. But only when I run my A/C. I beleive it is the freon in the lines "pressuring down". (If that makes any sense). Thats why it takes a minute for the cold air to start when you first turn it on...needs to build up pressure and start flowing.
Old Jul 12, 2005 | 10:19 AM
davdogg39's Avatar
davdogg39
i agree with the posts above, i am pretty sure its the A/C system hissing. My 92 Bronco does that only when the A/C has been working for a long time. Its been hott here too and i hear it when the engine stops just for a few minutes. I was alarmed to when i first heard it but i put my ear to the condenser one day and figured that was it. I had my AC recharged 4 years ago and still blowing cold air .
Old Jul 12, 2005 | 08:26 PM
XolieX's Avatar
XolieX
yea i checked it out and its not the radiator cap. its on the opposite side. i paid closer attention and its coming from a canister thing all the a/c tubes are coming from.
so this short hissing is normal huh. cool.
however, the temp is a little warmer than normal than usual, but again, its at least 90-100 degrees lately.
Old Jul 13, 2005 | 09:38 AM
BillyBob69's Avatar
BillyBob69
Yea it will be warmer when you run the A/C...especially on the real hot days. It puts additional load on the engine.
Old Jul 13, 2005 | 09:51 AM
poffutt's Avatar
poffutt
I don't think it is the AC. cus mine does the same thing and it don't have any AC but it has done it every since I'v owned it but it runs great.
Old Jul 13, 2005 | 09:58 AM
BillyBob69's Avatar
BillyBob69
POFFUTT.....sure there is always one to throw it all off.... :P
Have you stuck your head under your hood to see what it might be? If you don't have AC i am curious to know what it is.
Old Jul 13, 2005 | 10:06 AM
brokebronco's Avatar
brokebronco
The noise you hear is the A/C system pressures equalizing. There is a high pressure side and a low pressure side. The Compressor builds the pressure and the orifice tube located in the evaporator inlet is the transition point of the low pressure side. With the compressor turned off, the pressures in the two sides of the system seek to balance themselves out.
P-man, your noise is most likely the diaphram in the brake booster leaking. I had a Bronco that did that.
Chris
poffutt's Avatar
poffutt
don't know what it is, but it is exacly what is described. it hisses for about 15 to 20 seconds and gets less and less until it stops. Maybe it is the pressure of the fuel injectors. but in mine it is not the AC.
Old Jul 13, 2005 | 11:13 AM
kameronth's Avatar
kameronth
brokebronco is right on. It is the low and the high side balancing out. I tend to hear mine more when it is hotter outside. Yesterday it was 113* and it was really hissing. Going to be 115* today, so I am sure it will be hissing away again.
Old Jul 13, 2005 | 11:28 AM
BillyBob69's Avatar
BillyBob69
Maybe it's a pissed off snake under the hood getting ready to bite your a**.
Old Jul 13, 2005 | 10:45 PM
Cheggie's Avatar
Cheggie
I can really hear mine right by the accumulator after shutoff. Normal!
But you should never discount the snake theory, either.
