SBF headers
Old Jul 11, 2005 | 03:41 PM
imlowr2's Avatar
imlowr2
Unhappy SBF headers
I've been trying several combinations of headers on my 56 with the 289. I prefer the shorties but may have to use long headers. I've got a ton of room, yet every set of headers I try either hit the engine mounts or the steering box which is near the rear of the firewall. I need some headers where the pipes or collector go down near cylinder 7 and 8. anything after cylinder 8 will probably hit my steering bo 5.0 headers hit the steering box.). A friend of mine also has a set of cast iron hi po 289 manifolds. Is it worth putting these on in lieu of headers? Any suggestions on a header that might work with this setup?
Old Jul 11, 2005 | 04:16 PM
Homespun91's Avatar
Homespun91
Here'e a couple that might be a possibility, if I'm picturing your setup correctly. You can get an idea of dimensions at http://www.sandersonheaders.com/pagesbypartnum/ff2.htm They won't be particularly cheap. BTW, for factory manifolds, the 289 HiPo set isn't bad.
Old Jul 11, 2005 | 06:13 PM
imlowr2's Avatar
imlowr2
Homespun, thanks for the great post. The first picture might work for me. The second picture of headers, I already tried. They are very similar to the Motorsport block huggers, (I told you I tried a lot) The front corner of the collector hits the engine mount. I'll call Sanderson and check on the application for the first one. Thanks again.
Ed.
BTW, my buddy wants $50 for the two cast iron manifolds from the hi po.
Old Jul 11, 2005 | 06:35 PM
Homespun91's Avatar
Homespun91
Ed,
I believe I managed to load them backwards. The left pair is FF4, the right is FF2. Sanderson is good about accomodating returns, etc. & are willing to mix & match also out of different sets.
If they are HP manifolds, $50 sounds pretty good.
mavman
Jul 22, 2007 11:12 PM
mkrog
Jan 30, 2006 12:26 PM
mikenusaf
Jun 5, 2005 07:46 PM
Jim Larson
Feb 5, 2003 11:08 AM
