93 fuel pump location ?
Old Jul 11, 2005 | 02:15 PM
crossedover's Avatar
crossedover
Unhappy 93 fuel pump location ?
Does the year have three pumps like 87? I have looked all over the frame rail for a hi preasure pump.
Tank pumps run constanly when key is turned, instead of running for 2 seconds.
Both tanks do the same thing.
Engine will start but runs like crap.
Looking for hi preasure pump to test voltage.
93 f-150 5.8L
Old Jul 11, 2005 | 02:36 PM
GWall's Avatar
GWall
My '93 5.0 has two fuel pumps. One in each tank.
Old Jul 11, 2005 | 02:42 PM
quicklook2's Avatar
quicklook2
fuel pumps only in tanks.
Old Jul 11, 2005 | 02:45 PM
crossedover
Thanks for the quik reply.
Will change filter first and see what happens.
Old Jul 11, 2005 | 02:52 PM
quicklook2's Avatar
quicklook2
try resting the computer by disconnecting battery for at least an hour.
check fuel relay in main power box under hood.
both pumps do not usually fail at the same time.
someone on this forum said it is almost never just a fuel filter that stops vehicle from running.
Old Jul 11, 2005 | 03:17 PM
andym's Avatar
andym
If it gets plugged bad enough, it will. A plugged filter can cause low pressure, though. I know that from experience.
'89 and older has the inline high pressure pump on the frame rail.
'90 and newer has the in-tank pumps.
Old Jul 11, 2005 | 05:05 PM
EPNCSU2006's Avatar
EPNCSU2006
I would look first at the fuel pump relay to make sure it is not stuck, keeping the circuit live. Also try pulling codes from the computer to see if there are any that might help narrow down the problem. You can pull codes yourself; follow the instructions here: http://www.thorssell.net/hbook/eectest.html
Old Jul 11, 2005 | 06:34 PM
quicklook2's Avatar
quicklook2
i agree with epncu2006 on the fuel pump relay, but also the wires below the relay sometimes corrode so i would add that as something to look at.
Old Jul 12, 2005 | 10:38 AM
crossedover
OK, I changed the filter and that didn't help. I'll check the relay swich and try to read codes.
Thanks again.
Old Jul 12, 2005 | 11:42 AM
quicklook2's Avatar
quicklook2
by the way, the fuel relay is number 2, and fuel maxi fuse is number 16.
Old Jul 12, 2005 | 11:49 AM
crossedover
Thanks Quik, I just noticed a steady clicking coming from the distributor cap while the ignition is on. I was looking at the relay when I herd the sound.
The engine won't start anymore.
I'm waiting for a ride to purchase a code reader.
Old Jul 12, 2005 | 11:58 AM
quicklook2's Avatar
quicklook2
on your truck you do not need code reader only obd-2 does. do search for how to read codes for obd-1
Old Jul 12, 2005 | 12:01 PM
crossedover
Right, would need test light or analog volt meter.
Or is there somthing I'm missing?
Old Jul 12, 2005 | 12:52 PM
quicklook2's Avatar
quicklook2
go here to learn how:http://www.fordfuelinjection.com/
you just use wire to jump connector and watch lite in dash http://fordfuelinjection.com/?p=13
Old Jul 12, 2005 | 02:57 PM
EPNCSU2006's Avatar
EPNCSU2006
Follow the link in my previous post to see how to pull the codes yourself for free (or the fordfuelinjection.com one that quicklook posted).
