Need to get rid of 83 stepside in Austin
Got an 83 F100 stepside that I no longer use and would like to see it go to someone who would make some use of it. It is primer gray and rust. Bed needs to be redone and tailgate is on the porch. It does run, although it is in drive and will not select any other gears. It is a 302 roller from a late model Mustang, small block C6 and a Hurst ProMatic shifter. I will harvest at least the manifold and carb off it before I let it go. If whoever takes it does not want the motor, I will harvest it as well. Asking $300 with motor, $200 without.
