74 Ford F-100 front spring mount
Hello,
I have a '74 Ford F-100, short bed, 2WD, 3 speed manual on the column.
I've discovered that my right front tire is wearing funny because my coil spring/shock/suspension mount is rusted through. I welded it up early last year, but it has broken just above the repaired area. I've looked in the LMC catalog, JC Whitney, etc. but the mount is not available that I could find. Short of grinding one off in the junk yard, is there any place you know of where I can purchase one of these? The spring, the shock and the lower axel arm all attach to this piece that appears to be riveted onto the frame.
Thanks,
Steve
Thanks,
Steve
