Flexplate E4OD
Old Jul 9, 2005 | 11:15 AM
davisrats's Avatar
davisrats
Angry Flexplate E4OD
Ok, purchased a 1995 7.3 with an E4OD, around a 75,000. Standard cab, F250 4X4 a couple years ago. Ran good for about 30,000, just a turbo oil leak and a cam sensor.
This truck has had three flexplate installed and they cracked in less than 3000 miles. The trans was rebuild, new flexplate, new torque converter, ran less than 3000 miles, cracked the flexplate.
Took it to ford, had a ford rebiult trans and a new flex plate, 5000 and the same thing....
Engine endplay is fine, oil pressure and everything else looks fine.
Any ideas?
Old Jul 10, 2005 | 08:52 PM
davisrats's Avatar
davisrats
Trade it in on a Dodge I guess.
Ron
Old Jul 10, 2005 | 09:13 PM
Phydeaux88's Avatar
Phydeaux88
davisrats suggestions like that will not earn you any friends or respect here. If you dont like Ford trucks may I suggest you keep your mouth shut.
Old Jul 11, 2005 | 05:16 AM
dodgedh2's Avatar
dodgedh2
There was a TSB put out about this problem. Main cause was machining of the rear gear cover (machined cast aluminum part between engine and trans). The bad covers were machined off parallel and caused extra load on the flexplate. The fix was to change the gear cover AND the following p[arts (since they may be damaged after flexplate failure): crank spacer, flexplate reinforcing plate, crank bolts. Since your vehicle has 75,000 miles omn it, then it is possible that the gear cover is OK. These failures are usually low mileage. To tell if the gear cover is OK or not, remove it and use micrometers to measure the thickness of the cover all the way around. The measurements should all be well within .010" of each other. I've seen bad ones which were any where from .015" to .118" different. If your's measures OK, then I suspect that the other parts (crank spacer) was damaged during one of the failures. The flexplate for the 7.3 is pretty durable and doesn't really have any warranty history other than special causes like the gear cover issue.
Old Jul 20, 2005 | 07:56 PM
davisrats's Avatar
davisrats
Does anyone have this TSB or the TSB number, the Ford dealer says he can't find it.
Thanks
Old Jul 21, 2005 | 05:08 AM
dodgedh2's Avatar
dodgedh2
The original TSB was written against 1999 and prior PSD, however, it was supposed to have been updated to cover all 7.3L applications. The original TSB number is: 99-23-6.
Old Jul 21, 2005 | 07:52 PM
davisrats's Avatar
davisrats
Thanks for the info.
Old Jul 26, 2005 | 05:42 AM
dodgedh2's Avatar
dodgedh2
Let me know if this fixs your problem.
Old Jul 26, 2005 | 03:19 PM
davisrats's Avatar
davisrats
The truck is at the Ford dealer, it was back together, they claimed there was no TSB, after presenting them the TSB they disasembled the truck and now say there are parts on order.
Thanks again, will keep you posted.
Old Aug 24, 2005 | 08:32 AM
davisrats's Avatar
davisrats
Well the truck has been out of the stealership for a couple weeks now. About 1800 miles on it and so far so good.
Old Aug 25, 2005 | 05:49 AM
dodgedh2's Avatar
dodgedh2
I know it can be nerve racking, waiting and hoping it doesn't fail again. Keep us posted on your success. By the way, what parts did they replace? The TSB names several parts to be checked and/or replaced.
Old Oct 6, 2005 | 08:15 PM
davisrats's Avatar
davisrats
The crank spacer, flex-plate, engine spacer/housing, bolts etc were changed.
5500 mile so far, fingers crossed...
Thanks for the help
Old Nov 13, 2005 | 08:10 PM
davisrats's Avatar
davisrats
well it died again. same thing cracked flex plate. Too bad it was a great truck.
Old Nov 14, 2005 | 09:44 PM
wycowboy's Avatar
wycowboy
Put a 5 speed. In and keep the truck!
Old Nov 14, 2005 | 11:44 PM
Kwikkordead's Avatar
Kwikkordead
Sounds like the crankshaft is machined crooked or something. Everything else has been changed several times.
