drain plug issue E40D
Old Jul 9, 2005 | 09:35 AM
lossscause's Avatar
lossscause
hey guys, sorry about the stupid question, I cant seem to figure out which drain plug I drain on my E40D, I want to install my Sonnax kit and need to drain the tranny to do so. Anyone have any diagrams, or know where it is. thanks.
BTW, it is a 97 F350 w/E40D (OBS truck)
Old Jul 9, 2005 | 10:59 AM
l-m tech's Avatar
l-m tech
there is a hole at the bottom of the bellhousing ,remove the rubber plug and turn the engin till you see a 7/16 plug.remove the plug to drain the converter, drop the pan and that should get out 95% of the oil in the trans.if you are doing a shift improver kit remeber to only use paper towels and not red rags,and be as clean as possible.good luck
