Carb Orientation?
The engine had a bad flat spot at low rpms and on acceleration, I added a 50cc accelerator pump and that helped a lot. Still the low rpm torque seems kinda week, untill the engine revs up quite a bit there isn't much power available. Could the carbs orientation on the intake manifold have anything to do with that? I am planning to remount the carb "crossway" on the manifold with the primaries "outboard" on the intake manifold. I suspect the air/fuel flow to all cylinders would be more balanced. Will this help? Would a carb spacer help? I purchased a 1" spacer but I havn't installed it yet. I have completely rebuilt this motor, 9/1 pistons, ported and polished the head, stainless valves, roller rockers, ect. I am using the clifford "RV/torque" cam. I switched from points distributor to the ford duraspark. I am using a new stock coil. Would a hotter coil help? What about advance? I am using the original advance settings. I am thinking I should bump that 2-4 degs. just to see if it helps. Any suggestions would be appreaciated. Thanks
I have a friend that is following my design to split a Clifford manifold front/back to make it like a dual plane V8 manifold. This should increase low end response a lot. In the normal configuration it is set up like a single plane manifold that you all know is good for high rpm HP but bogs on the low end. You have to mount the carb so that you have a primary and secondary feeding each half of the manifold of course.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
