Success!
Old Jul 8, 2005 | 02:07 PM
crack's Avatar
crack
Success!
pulled out my tired 351M out of my 77 F150 and put in a less tires apparently rebuilt 400 from a 78bronco. bolted everything up found some carb that works, and turnedo ver a ltitle bit and fired right up. BUT its leaking liek water out of the head, so I dunno if its warped or something like that?
Old Jul 8, 2005 | 09:14 PM
danlee's Avatar
danlee
Where is the water coming out?
Old Jul 9, 2005 | 12:24 AM
crack's Avatar
crack
well it must have healed itself, because no more leaks, runs good now, probably almost twice the power as before, I could hardly spin a tire before now its 2nd gear for as long as I want!
Old Jul 9, 2005 | 10:42 AM
53fatfndr's Avatar
53fatfndr
You probably just had fluids leaked all over from when you did the engine swap, especially if you are messy like me, lol. It wouldn't be so uncommon, but I would keep my eye on things just in case.
Old Jul 11, 2005 | 10:15 AM
beartracks's Avatar
beartracks
If you had water leaks from around the head gasket I would retorque the head bolts.
