Timing Setting
Timing Setting
1966 352, Edlebrock CAM,INTAKE,CARB (their matched set) Mallory Unilite distribure (mechanical advanced) and headers and new radiator & hoses. What should be the INITAL timing or doesnt that matter??? All the info I can find says TOTAL TIMING
The reason Im asking is it seems perty hot under the hood and I went for a short test ride yesterday and the BRAKE FLUID tube coming from the master clyinder was HOT!!! Too hot to hold!!!
It looks like mechanic set it at 12 BTDC while idling.
12* BTDC sounds about right, with pure mechanical advance, even more initial timing might be needed(to aid part throttle response). You need to get a total of around 36* to 40*, so knowing what the mech advance you get from the distributor then allows you to adjust the initial to get that. As long as it does not turn over hard or "diesel" when shutting off.
The heat could be the result of fresh engine, they tend to run warm for awhile. Is the cooling system all functioning properly?
