Sponsored by: Auxito
need help!!
Old Jul 7, 2005 | 02:48 PM
mikeslate's Avatar
mikeslate
need help!!
I have a 2000 4.6 and once in a while when i step on the gas pedal it will hesitate and at times not even go for about a second or two and then all of a sudden it kicks in and Im on my way. any ideas of what this problem could be. Any advice would be apprciated. Thanks
Old Jul 7, 2005 | 04:29 PM
luttersj's Avatar
luttersj
spark plugs. air filter. fuel filter.
That's my uneducated guess....
Old Jul 10, 2005 | 10:23 PM
fordtech92's Avatar
fordtech92
check the plugs for carbon tracking along the insulators. I had the same problem with my 99 4.6. I put ford's WDS scan tool on it and did a cylinder balance test. I found it dropping 2 cyls. (1&3 on mine but they may differ) on accel. But I also have plug wires. If i'm not mistaken, ford started using individual coils for 2000. Either way, check that out, Depending on you mileage, plugs would probably be a good idea anyway. If there is tracking, replace your wires, or the coils on the problem cylinders
Dunnrightmobile
35
Mar 3, 2012 07:46 AM
Bill W
Arizona Chapter
42
Sep 10, 2010 02:31 PM
Brad Deicke
Aug 21, 2002 05:08 PM
Motor_Freak
Jul 30, 2002 06:46 AM
GrimReaper
Nov 30, 2001 03:24 PM
