Does this sound like an IAC problem?
Old Jul 6, 2005 | 07:04 PM
rollinXplorer's Avatar
rollinXplorer
97 SOHC 4WD 80k miles
Does this sound like an IAC problem? I will be at a traffic light waiting to make a left turn, I will wait maybe a minute or two until it’s clear and begin to make my left turn. On acceleration the engine cuts for a fraction of a second and then continues to operate normally. What’s odd is it only happens during turns especially U-turns. This may be a steering issue too since my steering is a little funky. Any suggestions are greatly appreciated.
Thanks,
Joe
Old Jul 6, 2005 | 08:47 PM
bwright's Avatar
bwright
the IAC is responsible for keeping the engine running while at idle. if the engine runs while idle, then it's not the IAC
Old Jul 7, 2005 | 12:06 AM
Jharger's Avatar
Jharger
Not necessarily. The IAC does control the engine idle but it is also opened up at other times by the PCM. For example, it goes full open under WOT and the injectors compensate to give as much raw power as possible. It also goes full open at TPS full closed and less than 1500 RPM - this is when costing to a stop for example. You don't want the engine to stall right?
So coming off idle to a partial throttle, a bad IAC could cuase a temporary lean condition resulting in a stumble.
Or, a bad linear potentiometer, or feed back device, could tell the PCM the IAC is open when it is not and then the PCM will add more fuel causing a rich condition and a slight hesitation.
Other things to consider are fuel pressure regulator, bad plugs/wires...anything that effects A/F mixture or spark delivery.
Not sure what a left turn has to do with it.
Key here of course - any CEL or codes in memory? Computer code readers are simply pure gold in diagnosing these "newer" cars.
CHeck out this sight for much valuable information on Ford EFI systems http://fordfuelinjection.com/index.php?p=39
Old Jul 7, 2005 | 05:47 AM
Bob Ayers's Avatar
Bob Ayers
I believe that the IAC only has 2 wires going to it, so there is no feedback telling the PCM how much it is open......
Old Jul 7, 2005 | 11:00 AM
Jharger's Avatar
Jharger
Did I say that? Sorry late night. Confused it with the EGR feeback. IAC runs open loop.
