1978 - 1996 Big Bronco
Window Weatherstripping
Old Jul 6, 2005 | 04:04 PM
rews2's Avatar
rews2
Has anyone ever replaced the weatherstripping at the bottom of the window, driver and passenger. It is the rubber type that sits against the window to prevent leaking into the door and rattles. Where did you get it and how difficult was it to replace.
Old Jul 6, 2005 | 07:09 PM
Streetgang's Avatar
Streetgang
Very easy to do on my 93.....got the set of four pieces (inner and outer window sweeps or window belts they are called) got them from Jeffs Bronco Graveyard.
I also did the rear window.
Old Jul 6, 2005 | 08:27 PM
Cheggie's Avatar
Cheggie
The outers are very easy to do - the correct way is to remove the lower window stop, and let the window glass slide down and out of the way - but I think I've worked around that before. They slide up and in, toward the center of the vehicle. To replace the inner, you have to remove the door panel because it's attached to that. The felts and rubbers are available from a lot of vendors, E-bay, LMC, Jeff's - generally under $50
