High water temp while towing
Old Jul 6, 2005 | 03:49 PM
mr_glass's Avatar
mr_glass
94 tubrodiesel (non-powerstroke), Automatic with 410 gears, turning around 2000 rpm at 60 mph. How high is too high on the temp gauge. I am pulling a 7000 lb enclosed trailer and it is near 100 degrees outside air. Truck runs high m low a while driving to the track. Pyro meter is staying between 10 and 11. Has anyone check a manual gauge to verify what temp is at what letter? Thanks for your help. Chris
Old Jul 6, 2005 | 04:17 PM
bilder12's Avatar
bilder12
Chris - if you are maintaining the pyro at 1100, that might be the problem. you have to give the engines a rest sometimes. Try backing out of it for a while and see if that allows the temp to drop. You may be overfueling it. Also, if the fan clutch has mileage on it, you might need a new one, just dont let the temp go way up. hope this helps you out.
deanj's Avatar
deanj
Install a manual temp guage in place of the stock. They do not call them idiot guages for nothing. I can give you the theoretical temps vs ohms but they are only rough.
212 F = 177
194 = 241
158 = 467 etc
Old Jul 6, 2005 | 04:23 PM
deanj's Avatar
deanj
Did not get to finish, 1100 for a long time is not good, that will add to the increase in temp. Remember 1240 is the melting point of the pistons. Have you checked out the cooling system, fan etc. What trans temp are you running ?
Old Jul 9, 2005 | 12:39 AM
PLC7.3's Avatar
PLC7.3
I would like to advise all the members to clean the A/C condensor fins and the radiator fins with compressed air then water. If you do/did off roading check for mud buildup it can be hard like baked clay.
We have seen many in the past weeks plugged to the hilt, in fact one had enough straw and field crud plus mud to fill a 5 gallon pail. The clutch fan worked fine but no air was passing to it, consequently no cooling.
Old Jul 11, 2005 | 01:32 PM
mr_glass's Avatar
mr_glass
Cooling problem
Thanks for all the advice. Looks like I have found one problem. Noticed the temp gauge was going very low when not under load. Changed the thermostat and found it was stuck open and the rubber gasket was gone. Don't know what the rubber gasket does but alldata was very insistant it was there. Next trip it never got to the A and would cool down much faster after a hill.
Would still like to get better cooling. Has anyone tried to use the aluminum radiator that you can order for the 460 truck?
Thanks Chris
Old Nov 22, 2005 | 08:55 PM
dhumphri's Avatar
dhumphri
Hi Chis - I was talking with an IDI owner last night who was concerned about slightly higher than normal temps on his truck and he had a modified impellor fitted to his water pump. Temperatures regularly reach 50 degrees celsius where he lives and has never had an issue since(he is located in Western Australia).
Regards
Darren
Old Nov 22, 2005 | 09:13 PM
mr_glass's Avatar
mr_glass
Water temp
Hello Darren, Thanks for the info. Do you have any details about the modified impeller? I need to do something and was going to change the water pump this winter anyways. Thanks again Chris
Old Nov 22, 2005 | 09:25 PM
dhumphri's Avatar
dhumphri
Hi mate - will be talking to my mate tonight, will try and get the specific part details for the impellor. Darren
Old Nov 22, 2005 | 09:29 PM
mr_glass's Avatar
mr_glass
Water temp
Thanks Darren
