Hello, and headlights??
Old Jul 6, 2005 | 12:12 PM
v8buick's Avatar
v8buick
I have a 1994 F-250 4x4, 125,000 miles. My headlights have started to flicker and go out. Get this only when the truck is running and in reverse. Shut the motor off and they come on or quit flickering. I pulled my trailer plug-in out and put the tail set up back to normal, checked fusses and wires and grounds. I have not pulled the dash out yet. Ever hear of anything like this. Thanks Mark Rehr eastern Iowa
Old Jul 6, 2005 | 12:42 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 6, 2005 | 01:41 PM
frederic's Avatar
frederic
Sure, I would have suggested loose wires, weak grounds, all the stuff you checked.
Also check the headlight switch, maybe it's dying or the connector on the bottom is loose, maybe the spade in the fusebox is loose and wiggling... you're on the right path!
Old Jul 6, 2005 | 02:17 PM
egress's Avatar
egress
had same problem in both a 94 and 93 it was the wires going to switch they try and melt to the switch to fix just put on new connectors and hook back up never had problem again
Old Jul 6, 2005 | 02:31 PM
v8buick's Avatar
v8buick
Thanks
I have to go to work now, will check the switch in the AM. Mark
Old Jul 8, 2005 | 11:25 AM
v8buick's Avatar
v8buick
light switch
I pulled the light switch out and the wires look new, I cleaned the contacts and put it back and still have the flickering lights. I may try a new switch. I also had the lights on and played with the wires and connectors while the switch was out with no luck.Mark
Old Jul 10, 2005 | 01:46 PM
v8buick's Avatar
v8buick
new switch
I put in a new switch and it did not help. Still checking wires. Mark
Old Jul 10, 2005 | 07:29 PM
Popa Tim's Avatar
Popa Tim
Only in reverse??? Do your reverse lights come? Possible that there might be an intermittant short there?
Old Jul 10, 2005 | 08:40 PM
v8buick's Avatar
v8buick
all gears
It's now doing it in all gears but only when the truck is running. If I shut the ignition off the lights become steady. Mark
Old Jul 10, 2005 | 09:45 PM
Popa Tim's Avatar
Popa Tim
Somethings loose!
Check the body ground located just in front of the battey. Clean it up really good!
Check the solenoid too. Maybe a wire there is loose/corroded.
Old Jul 17, 2005 | 11:58 AM
v8buick's Avatar
v8buick
things I have fixed
Found a broken ground from the body to the frame and fixed. I found a broken bracket with a ground from the firewall to the engine and fixed it. Cleaned contacts. My lights still go out in revers with the motor running and come on when I shut the motor off. I hooked up my snow plow witch I have had since the truck was new and the lights work just fine. I also put on a new brake cross over line between the front wheels, it was leaking in the middle. Mark
