i have a '91 Bronco, and last winter my transfercase started to slip in 4wd, like it was making a grinding noise when id back off the throttle, so i figured with 120k it was prolly just worn out.
BTW, it is a Borg Warner 1356 manual shift.
so i was wondering if there is a differance between the transfer cases, in the differant years. because i have a line on a t-case from a 86 F150 302/AOD, it has the same shift pattern, is it the same t-case?
LMC also has a reman one for $900, but its also for a 80-86 bronco, so are these differant t-cases, willthey fit my 91? any
input is appreciated
