A/c help
Old Jul 6, 2005 | 09:41 AM
91f150asc's Avatar
91f150asc
A/c help
I have a 91 f-150 w/5.0L engine, the problem I am having is air will blow cold for 20 minutes after start up then starts blowing warm. If truck is shut down until it cools it will run cool again for a while then turns to warm again. If its cloudy out it will run longer and if I turn it on at night it will stay cold. It still is running R-12 which is at about 25 psi. on low pressure side. Someone told me to clean evaporator coil, which I did but no change. Also if I leave it idle, after cold start in driveway it will continue to blow cold air. Any suggestions will be appreciated.
Old Jul 6, 2005 | 10:55 AM
goofy173's Avatar
goofy173
25 psi on low side is too low and possibly the low pressure cutout switch is cutting it out. Or now that I think about it, your system is freezing up. Gotta get that pressure up to 35 psi on the low side.
OR
Slipping belt on A/C clutch.
Is the A/C clutch even running when the output vents become warm?
WheatWhacker97
Jul 28, 2015 12:57 PM
Dcook136
6.4L Power Stroke Diesel
Jan 14, 2015 03:14 PM
97ExpGuy
Jun 24, 2014 07:01 PM
texas4x4
Dec 17, 2013 08:26 PM
tidexp
22
Jul 2, 2012 08:30 PM
