Window Regulator
Old Dec 28, 2002 | 08:05 PM
BIG A's Avatar
BIG A
Window Regulator
Old Jan 3, 2003 | 11:55 PM
1979meangreen's Avatar
1979meangreen
Window Regulator
Does anyone know if a window regulator for a 1984 F-150 will
work in a 1979 F-150?
Thanks
Old Jan 5, 2003 | 06:56 PM
broncoman85's Avatar
broncoman85
Window Regulator
Not sure but tomorrow I'll do some measuring out in the junkyard and find out...will post back here with what I find. Later Whit
Old Jan 7, 2003 | 07:58 PM
broncoman85
Window Regulator
Hey MeanGreen, did some measuring today...the mounting bolt pattern is very different, looks like you might could make it work with some patience and a little fabbing but as far as a bolt in, no it wont work. Later Whit
Old Jan 7, 2003 | 08:37 PM
Mike W's Avatar
Mike W
Window Regulator
I bet the little gear can be removed from the older one and would work on the newer one. I assume that is the worn out part.
