...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
If you use a FL1995 PSD or IH FL 3630 filter which is 1 qt larger (better filtration) you would use 11 qts total US, if you use the standard sized filter FL 748 total is 10 qts US.
Please go up to quick links and put some info re the truck and your location in a signature.
Use a good grade of diesel oil like Shell Rotella T 15-40 or any other Diesel rated oil. You may want to shorten the change period from 5000 miles to 2500 miles for the first two changes if it is that bad and you know the PO did not change it regularly.
PLEASE REALIZE THE OIL GOES IN CLEAN AND TURNS BLACK AS THE ACE OF SPADES IN 3O SECONDS OF RUNNING, JUST THE NATURE OF THE BEAST.
