Difference between egr and nonegr Engines
Old Jan 8, 2003 | 09:34 AM
bluemustang's Avatar
bluemustang
When I ordered my 390 they asked EGR or nonegr engine, do they build them a different way. The reason I ask is because when I ordered my about a 1year ago I got the EGR one because I had one on mine. But now I'm going to take it off because I'm going to a four bbl intake and carb. Can any one explain the difference?
Thanks
Old Jan 8, 2003 | 02:58 PM
dfisher1's Avatar
dfisher1
Blue,
There is a port that allows exhaust gasses to recirculate when used with the egr plate. This port could be blocked off to eliminate the EGR. If your going for the street/strip mode just order one for non-egr and get on with it!
My Way is the Highway,
KingFisher
Old Jan 8, 2003 | 03:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
The EGR is the Exhaust Gas Recirculation valve. It is an emission control that reduces the NOx or oxides of Nitrogen that form during the combustion process. The valve circulates a small amount of exhaust gas back into the engine at certain times to reduce combustion temperatures. On an "EGR" engine there are frequently passages buit into the intake manifold to supply the exhaust gas to the EGR valve. A non-EGR manifold will not have these passages. The EGR valve does not have any effect on the maximum power output of the engine. Without an EGR valve the engine will ping under light throttle loads unless the distributor advance curve is changed.
Thanks for using FTE!
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID75&conf=genconf |Garage and Shop] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID116&conf=DCConf ID9|Ranger] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID91&conf=DCConfI D12|1973-1979 Ford trucks] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID93&conf=DCConfI D8|1997-2003 F150 and E150 Forum]
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Jan 8, 2003 | 03:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
New information from Blue:
I just ordered the Edelbrock intake and Ceb for my 75 F100 390. It has a egr 2bbl intake with a motorcraft 2100 on it right know. Will I be able to tell a big difference in it. Has anyone else done this and what difference could you tell?
I hope it comes in before saturday so I can put it in saturday.
Reply by dfisher1:
Blue,
We know what comes on it stock. What did you order?
Chances are it won't be much faster.
KingFisher
<Info moved by moderator to keep the entire discussion in one topic for clarity>
Old Jan 8, 2003 | 04:09 PM
85351ho's Avatar
85351ho
77 Bronco
32
Sep 23, 2017 10:56 AM
Matt5324
19
Jul 28, 2014 03:46 PM
MyName1sMud
Aug 6, 2013 06:24 PM
wall77
Nov 12, 2009 07:36 AM
crawlfish
15
Nov 3, 2005 07:28 PM
