Tranny fluid flush
Old Jul 5, 2005 | 10:46 AM
1995fordf150's Avatar
1995fordf150
Tranny fluid flush
This is my first post. Just got a 95 Ford F150 automatic with the inline 6. This truck has 150k miles. I should have the E40D tranny right? I plan on doing a tranny flush and changing the filter. I did this once on my crown victoria by disconnecting the cooler lines and running the engine for a minute to get fluid out of the lines, dropping the pan, and rotating the torque converter so I could pull the drain plug on it. Can I do this truck the same way?
Is there a converter drain plug? Also, is there a reusable rubber gasket on the pan like on my crown vic? Any suggestions?
Old Jul 5, 2005 | 11:54 AM
quicklook2's Avatar
quicklook2
convertor drain is covered by a plug, remove than rotate. new gasket comes with filter. add lucas trans treatment or shudder fixx to prevent torgue convertor shudder. much written on this go back a few weeks or do a search.
welcome!
