just to add onto what I posted, knowing the backpressure/ flow also helps in determining the antcipation of when to back off the VVT for a more seamless operation.
WeKiwa-thanks for bringing this up. It's been bothering me a while too...
Maybe it would be nifty if one of the programmers took the exhaust back pressure reading into account with one of their performance tunes and someone offered a sensor that would work with your free-er flowing exhaust...rather than ignoring the sensor and making changes that keep it from working properly how about trying to work WITH the sensors we have and still feed the ECU all of the data it needs to run as well as possible?
-pretty much the same idea as the recalibrated MAF's all the NA folks get...this is just on the other side.
You know I wondered about an exhaust pressure sensor but didn't presue as I didn't see one.... When I return home I'll dig a little deeper this time.
The HP stuff should be waiting for me too so next weekend will be party time!
thanks to all for the info.
Back to tyeing things down and waiting for Dennis to LEAVE! My folks are freaked over this one. Me...I'm thinkig about the mods...
It is not a matter of backpressure for it to operate but more along the line of being able to monitor it. Pressure sensors have a sensitivity to them, if you trying to sense pressure changes lower than the sensitivity(larger exhaust, etc.), the computer won't recieve an acurate reading from the sensor. With a known orfice(size of the piping to the cat) and with a pressure reading, engineers can calculate how much volume is passing thru the turbo. Knowing the volume, the engineers can "map out" the volume /boost output curve(given output of a pump/fan at a know speed/pressure drop) of the turbo. They can better program the ECM to control the engine/turbo better (make it meet emissions).
I believe the ability of the ECM to know the back pressure is central to the fuel mileage drop that I and others have experienced when changing to a larger down pipe and exhaust. I lost around 2-3 mpg around town, and I truely believe the ECM is now using a "non-optimum" map for its calculations for volume/boost/timing. More specifically in my case, the EGR valve operation under part throttle I believe is the cause of my mileage reduction. With the new lower back pressure readings from the new exhaust, the EGR maybe be opening "wrong" and causing the mileage loss. Unplugging the EGR recovers all the mileage I lost with the exhaust change. Your mileage may very of course
Im sorta dissaponted i didnt do some kinda track time with my truck, Pre Stright pipe..
The thing that i remember most with stock exhaust was the truck having the "sence" of more power, As in the way the power was deliverd when Stomping down.. It seemed to jerk you back Very hard.. Now it seems to be a more smooth power delivery. Plus with stock pipe and the SCMP it would bark the tires from 1st to 2nd, 2nd to 3rd and in cold weather 3rd to 4th... Now it wont do it at all... Plus a 3-4mpg decrease.. O well, at least it sounds Sexy..
