Starter problem
Old Jul 4, 2005 | 03:59 PM
whaynswo's Avatar
whaynswo
Starter problem
97 Expy, 140k miles... the engine will turn over, but immediately die... not a problem with the battery... any ideas??
Old Jul 4, 2005 | 05:34 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
By the way, what does your screen name stand for, curious I am?
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 4, 2005 | 07:40 PM
PaulC's Avatar
PaulC
Try to start it again, but this time press and hold the accelerator pedal about 1/8 down. If the engine runs, but stalls when pedal is released, good chance that the IAC (idle air control) valve is stuck or dead. Do a site search on IAC valve.
Old Jul 4, 2005 | 08:42 PM
whaynswo's Avatar
whaynswo
yes, it will run briefly while holding down the pedal...then die when released... i'll search for the fix... is it relatively easy and inexpensive to fix? thanks!
jason
Old Jul 5, 2005 | 08:03 AM
jakermc's Avatar
jakermc
IAC valve should run $60 - $80 for the part. Easy DIY job - simply remove two bolts to pull off the old valve. Put new one in its place and put the bolts back in. Only issue is the valve is very hard to reach, its all the way in the back of the engine. Your symptoms are classic for IAC valve, I'd be surprised if it were anything else.
