Air bag light 2000 Explorer
Old Jul 4, 2005 | 09:24 AM
myveryfirstford's Avatar
myveryfirstford
My air bag light blinks for a bit then stays on. There was no owners manual when I bought the vehicle. What does that mean?
Old Jul 4, 2005 | 10:18 AM
mason's Avatar
mason
You have a fault in your supplemental restraint system, SRS. Count the flashes. There should be a number of flashes followed by a pause then a number of more flashes followed by a pause. This gives you a two digit number that will tell you where the fault is. After a number of theses sequences the light will then stay on. Most likely a 36 or 37 indicating a problem with the driver's or passenger's seat, respectively. Oftentimes a a problem with a connection under the seat caused by people sticking their feet under the seat. Count the flashes and report back for more details.
Mason
Old Jul 4, 2005 | 08:20 PM
oshoguno's Avatar
oshoguno
There are lots of posts covering the air bag fault codes. It would be a good idea to do a search of the Explorer forums, rather than have everyone repeat themselves.
Old Jul 8, 2005 | 12:52 PM
myveryfirstford
Back from vacation and read your answer to my thread. It's blinking 3 then 7 so that means 37. There's connections under the seat possibly loose???? Is that where I start?
Old Jul 8, 2005 | 12:59 PM
mason's Avatar
mason
Yes, start there.
Masonh
Old Jul 8, 2005 | 03:06 PM
oshoguno's Avatar
oshoguno
usually a broken wire at the connector from whomever in the back seat kicking it.
