Hi Michael and Welcome to FTE! This will help you navigate through FTE a bit better: https://www.ford-trucks.com/forums/s...d.php?t=300691 Also, check out your local State Chapter (located at the bottom of the main forum page).
Ya, we have a GREAT thing going here. And it only gets better from people adding to it. So be sure to share your knowledge with others. If you have a question, scroll to the applicable forum and post away.
Hey Matt, I have a 1979 f-250 custom 4x4. Dana 44 front, Dana 60 in the rear, B/W T-18 Tranny and NP 205 Transfer Case. It currently has a 351m that is totaly shot and I'm hopeing to replace it with a 300-6. I've completly gone through the front end IE new pads, rotors, seals, calipers ,lockouts and front driveshaft rebuild. Next Comes the rear brakes and lower steering shaft. Well thats were I currently stand, hopeing to get started on it again this summer. Michael
