96 ranger xlt, 3.0, got a new fuel pump relay, but there are 3 identical relays in the fuse box, i dont have an owner's manual, can someone tell me which relay is which?
Not sure how you plan on fixing ANY kind of an electrical problem if you dont even have the owners manual for your truck.
Yours might be different, but the Ford "electrical & vacuum troubleshooting manual"/EVTM for a 97 shows 3 relays, the PCM power relay & the WOT AC relay are side by side & the fuel pump relay is just above these.
Or if your sure theses relays are exactly the same,just swap them with each other & see if the fuel pump runs.
You can buy the EVTM & owners manual at www.helminc.com or maybe find them on E-bay.
