brake pedal brackets
Old Jan 10, 2003 | 08:37 PM
ST_Wilson's Avatar
ST_Wilson
Old Jan 11, 2003 | 08:33 AM
76swb's Avatar
76swb
Okay guys, I need to know if I need to change out the pedal arm BRACKET on my power brake conversion. Going from manual disc brakes, no cruise control, to power front disc brakes,with cruise control. I know the arm is different, I just need to know if I need to change the bracket also. Thanks
Old Jan 11, 2003 | 12:02 PM
Mil1ion's Avatar
Mil1ion
You never mentioned what year/model truck you have.
There are many combinations.
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Jan 11, 2003 | 12:26 PM
76swb's Avatar
76swb
Soory Dennis, that's a 1976 F100, 2WD.
Old Jan 11, 2003 | 12:43 PM
Mil1ion's Avatar
Mil1ion
Check to see if there are TWO holes for pedal lever to attach.
Also, if the M/C arm attaches to a bolt or a shaft with spring keeper.
It should be a bolt.
Dennis
Old Jan 13, 2003 | 03:39 AM
docholiday72tx's Avatar
docholiday72tx
John, I have a 73 f 100 that had manual breaks until 2 weeks ago. A manual pedal and a power pedal are a little different, but both will bolt up to the same bracket. The little bracket that holds your break light switch on a power pedal is about an 1 1/4" to an 1 1/2" closer to the seat. In order to make the break lights function correctly you will need the power pedal. Converting from manual breaks to power is a very simple bolt on procedure that took less than an hour. If you have any further questions, feel free to e mail me.
