460 Oil Pans
Well, I found a solution for the 460.
The '79 and earlier oil pan is a large front sump, with the oil drain plug is right over the rear of the cross member. Yuck.
However, Ford makes a neat racing kit, with a rear sump oil pan. The kit includes the rear sump pickup and all necessary hardware.
BUT, this gets better!
The '80 - '86 oilpan looks almost identical to the racing one! The '86 460 I just put in my '66 has the rear sump oil pan, as does the '83 460 I bought for the transmission. The cool thing is, the drain plug is in the rear, and is in the clear.
(Hey, that rhymes! I must be a poet and don't know it; my feet aren't Longfellows.)
So, look for an oil pan from '80 - '86. Be sure to get the pickup tube, and the meain cap bolt that holds it in place.
I cross posted this to the '67 and the '61 forums as well.
Doc
