94 Explorer ABS Problems
Old Aug 27, 2005 | 11:31 PM
Jharger's Avatar
Jharger
"Excuse me while I go find my bottle of Liquid Wrench."
Sounds like -Excuse me while I whip this out..... Blazing saddles fans?
Old Aug 29, 2005 | 01:42 PM
Craig789's Avatar
Craig789
I should have rented Blazing Saddles instead of trying to get the two old speed sensors removed. Ended up using a 3 foot crow bar. One came out and one came apart. Trouble is none of the stores I've been to have the exact replacement. Mine has a two foot long wire attached to it before you get to the connector. All the replacements have a connector socket built right into the sensor, thus requiring no new wire. Anybody seen this? Anybody got a model no. for a replacement? (94 expl, 2wd, cruise).
Recommend everyone who ever removes their front rotors polish up the business end of the speed sensor (w/o removing it) while the rotor is off. Mine works off magnatism and collects stray metalica. I think a simple wipe when I did the brake/rotor job would have been enough, but no, I had to do the job "right".
Old Sep 22, 2005 | 11:29 AM
94Explorer's Avatar
94Explorer
Try a dain, flush and refill.
The last time I went to Midas and that will be the last time they installed new disk pads and failed to properly bleed when pushing the caliper back. Well I had irratic faulse ABS response. That was cleared up when I had the brake fluid completly purged and cleaned. Works great now.
Riskyguy
2004 - 2008 F150
Jul 20, 2014 01:49 PM
Firefighter 1406
May 1, 2011 09:55 PM
blackout150
Feb 14, 2009 09:55 AM
rhnasko
May 1, 2004 05:19 AM
sytsmar
Aug 4, 2001 11:30 AM
