Sponsored by: Real Truck
Rear End
Old Jul 2, 2005 | 06:00 AM
jditton's Avatar
jditton
Rear End
I have a F350 King Ranch 4x4 and when I back up the rear seems to bind up, I get a jerking motion. My dealer first put in an additive, then changed the rearend and finally got it touch with the factory who said it was normal since it was a limitied slip it was just the clutches. Anyone else had this problem?
Old Jul 2, 2005 | 10:19 AM
99f350sd's Avatar
99f350sd
When you back up straight the clutches don't come into play and the truck should act normal..If it doen't then something is wrong for sure. Turning while backing up may cause some chattering as should going forward if the rear clutches are causing a problem. It shouldn't do it if all things are correct.
