1978 - 1996 Big Bronco
Rear end noise
Old Jun 30, 2005 | 11:23 PM
Freakazoid!'s Avatar
Freakazoid!
Rear end noise
I just finished a clutch/pressure plate/clutch slave replacement, and after I got everything back together, I now have a strong vibration and noise coming from the drivetrain. I thought it was the transfer case (because it is noisy in general) but now I am sure it is the rear end. The noise and vibration change with vehicle speed, not engine speed. I put the Bronco up on jackstands and ran it in gear - sure enough the noise comes out of the rear end. I popped the cover off and took a look, and everything looks OK, wear patterns seems a little to the outside of the ring gear, but I did notice that the spider gears that are not connected to the axles are loose. Is this normal? I seem to remember that when I bought the differential (rebuild done about 2 years ago) that the spiders were all tight, but I'm not sure. The pinion is tight, and there's no leakage anywhere. Suggestions? It's a limited slip differential, and I did put the traction modifier in with the oil.
Old Jul 2, 2005 | 07:02 AM
Freakazoid!
Turns out that the problem was the pinion bearings were shot. I should get that fixed today, and hopefully without any more noise.
