transfer case
Old Jun 30, 2005 | 04:25 PM
chrono4's Avatar
chrono4
transfer case
is it possible to get a trascase stuck in rear lo? the truck is a 88 f150. i was using the truck in a freinds feilds, in 4 lo. now it shifts hard into 2nd and im in 4 going only 35. how many speeds is a aod? not sure wat the case is. the front driveshaft doesnt spin when in 2wd, but i cant feel the difference between 2hi and 4 lo.
Old Jul 3, 2005 | 07:13 PM
chrono4's Avatar
chrono4
common, somebody?
Old Jul 3, 2005 | 08:56 PM
Mike38's Avatar
Mike38
Well for starters, what type of TC do you have. It is possible for it to get jammed with debris or if it just breaks. Try changing the fluid and seeing if that helps.
Mike
Old Jul 4, 2005 | 06:51 AM
1979bronco's Avatar
1979bronco
With a 205 t/c.When mine did that.I just backed up a bit.Try that and see what happens.
Old Jul 4, 2005 | 01:01 PM
MustangGT221's Avatar
MustangGT221
The 88 should have a borg warner, probably 13-56 or maybe 13-45. It's stamped right on it.
There is no "rear lo"....the transfer case either has 2H 4H N or 4L.
When you say "shifts hard into 2nd and im in 4 goin 35"...I assume that means your in 4th gear of the AOD? The AOD has 4 forward gears. If you're going in 4th gear at 35mph then you're still in low range man.
Sounds like you're in low range and the AOD is shifting you through it's 4 gears while you're in low range. It would do that if you've got it in D and in 4L.
The front driveshaft is not suppose to spin in 2wd, hubs unlocked. If the hubs were locked, the shaft will spin but the transfer case would be what's not applying torque to it. Once you shifted it into a gear, it would apply torque to the front end.
You should easily be able to tell the difference between 2H and 4L. If you want to, put the transfer case in 2H and put the gear selector to 1 instead of D. Take off smoothly, the RPMs will come up and the transmission just won't shift out of 1st gear, you've locked it in 1st gear. Now, put the transfer case in 4L and notice how much slower you go? Thats low range. It's ment for off road situations where lower speed and more torque are needed.
I have my off road truck setup to have a lower low range. My truck will only go a few mph in low range 1st gear.
