New Poster With A Problem
Old Jun 30, 2005 | 01:12 PM
SURVIVOR's Avatar
SURVIVOR
Hello, I am new here. I have a 1994 ranger with a 4.0 v6 engine w/ 109,000 miles on it. The problem i am havig is the tachometer will all of a sudden start getting erratic then go to 0 then check engine light comes on and the engine starts sputtering. when i am at a stop light when this happens and i take off in 1st it is like i am taking off in 4th or 5th. then suddenly everything works fine again for awhile. Any suggestions? thank you.
Old Jun 30, 2005 | 01:50 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 30, 2005 | 08:16 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
You should pull the codes, the CEL means you have codes, see the procedure "pulling eec-iv codes" in the tech info thread at the top of this forum.
Old Jul 1, 2005 | 08:25 AM
jimw411's Avatar
jimw411
sounds like maybe a crank or cam sensor, or a coil problem. Listen to Ken though, pull the codes and go from there.
