E4OD Trouble
Old Jun 30, 2005 | 07:17 AM
Fishman4's Avatar
Fishman4
E4OD Trouble
I have a 91 F150 with 109k on it. Still runs pretty good, but the trans wants to slip a little in first gear if you get on at all and it will sometimes snap your neck shifting from first to second and even kinda hard from second to third. Fluid level is good, no leaks (none worth mentioning anyway), and no unusual noises. Anyone got any suggestions where to start? I am more of an engine guy than a tranny guy and would appreciate any assistance.
Fishman4
Old Jun 30, 2005 | 07:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
MOVED and member notified
Old Jun 30, 2005 | 08:10 AM
one02fan's Avatar
one02fan
I have a 91 f 150 that sputters when trying to maintain a speed sputter lessens when accelerating or letting off gas...any ideas?
Old Jun 30, 2005 | 08:42 AM
Fishman4's Avatar
Fishman4
oneo2fan,
Have your ignition control module tested. Mine did the same thing for a while at low rpm. Turns out that the low rpm circuit was bad and eventually the whole thing went out and left me stranded. You can get the part just about anywhere for around $30.
Fishman4
Old Jun 30, 2005 | 09:08 AM
one02fan's Avatar
one02fan
thanks for the help
Old Jul 1, 2005 | 06:39 AM
IB Tim's Avatar
IB Tim
Welcome one02fan.....to FTE
