transmission fluid
Old Jun 30, 2005 | 07:16 AM
Industrial_dude's Avatar
Industrial_dude
transmission fluid
to run the suncoast extreme duty kit and converter w/ chip should I run a different type of ATF? if so which one? how many different types are there?
thanks
Old Jun 30, 2005 | 07:25 AM
captchas's Avatar
captchas
Guest
for your trans stay with what the factory states.
Old Jun 30, 2005 | 09:37 AM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
thanks
Stick with Mercon SP. You won't need the additive package for the clutches any longer, but the shift solenoids and pressure regulator still need it to have a decent lifespan...
Old Jul 1, 2005 | 04:27 AM
Industrial_dude
is mercon sp what comes in it from the factory?
I have a mag hytec deep sump pan, I forgot to ask how many quarts it holds does any one have any idea?
Old Jul 1, 2005 | 02:11 PM
SpartanDieselTech
Former Vendor
Yes, SP is from the factory. Stock capacity is 18 quarts, if the cooler and torque converter are empty. Add the added pan capacity rating to 18 quarts to calculate exactly how much you will need.
