Have you checked to see if the a/c drain fix has been done on it yet?? I had a 97 expediton that would run real rough. Turns out the problem was the cold water from the a/c was dripping on the passenger side hego sensor, and screw it up. the fix is cheap if thats your problem, just find someone to print out the fix from alldata.
Sometimes things just break. A guy I worked with at a dealer bought a CV and had a similar problem, turned out to be the same thing you have. He fixed it and is still driving it. As far as other damage, I can't answer that. Good luck, Rob. Keep us updated.
well reinstalled the rocker arm. Put everything back together, started it up and
so far so good. I have not actually driven it yet, but I can tell its much better.
Still has a slight miss when you give gas, scanned it and got code p0351.
I know it has to do with a coil.....I'm cool with that as long as I dont have to pull those heads!!!!
I'm going to change the oil and take it for spin in a bit.
